Monitor refresh question
    So as long as my refresh rate is >= my fps, I should see smooth frame rates? [/B]
    yup that is how i feel as well... anyways if i get anywhere between 60 - 80 fps i would be very very happy.. but i wouldnt mind a fps of 35 to 40 if the games are very smooth with no jerking.
    Life is a bed of roses. Everyone else sees the roses, you are the one being gored by the thorns.
    AMD PhenomII555@B55(Quadcore-3.2GHz) Gigabyte GA-890FXA-UD5 Kingston 1x2GB Generic 8400GS512MB WD1.5TB LGMulti-Drive Dell2407WFP
    ***Matrox G400DH 32MB still chugging along happily in my other pc***
      The higher refresh doesn't guarantee smooth frame rates. It guarantees that there will be no tearing effect between refreshes (if vsync is enabled).
      Frame rates depend on the capacity of the PC to generate enough frames per second.
