@ Fat Tone : 1333MHz should be considered a bit of a minimum. I can't remember the site, could have been techreport or Hardware.fr, where they tested 1333 to 1866, there is one inbetween as well.
The difference wasn't huge, but it was noticeable, and especially in Games. The integrated GPU only uses one 64-bit memory channel (probably two interleaved 32-bit channels), so memory speed will always help.
It'll still be pretty good, better than most laptops, and you have the option of plopping a PCIex16 card further down the line if you feel the need for speed
@VJ : I read that as well. My current dream machine is a Tri-Fire AMD setup with an Nvidia on a 4x for PhysX support. I also want to have single slot cards, so on the actual 6950/6970 I wanted to cut off the topmost DVI connector. Decided to wait and see what the 7xxx series brings, and from the rumours, they will come with one DVI, two mini-DP, and an HDMI, so should be single slot capable. I want to watercool everything, so single slot will be possible
Have to upgrade my NAS system though witth the Chenbro mini-itx case.
Looking at these :
Motherboard : http://www.materiel.net/carte-mere-m...-b3-65952.html
CPU : http://www.materiel.net/processeur-s...20t-70479.html
Mainly so I can have the possibility of RAID5, and have 6 Sata connectors, 4 for the removable drive trays, one for the DVD/BluRay and one for the internal 2.5" boot drive.
I only know of one other mini-itx board with six Sata connectors, and its Atom based by Supermicro.
Will probably get it in Jan-Feb, got some parts for the old Passat to get first.
Looking at these :
