Everything
    Thanks!
    Just checked with a friend and he said the ISP sells a GPON spf that should be compatible with my gear.
    Hopefully this way I can avoid renting any crappy gear.
    Still doing homework. I also see the ISP is selling a cheap TPLink fiber-copper, so I suppose getting the GPON sfp would be enough.
      Great to hear!
      Mine only offers their modem-router and no support or specifications on third party GPON solutions. For now I'm not bothered and just managing with a double NAT, but if at one point I would decide to update the router, I may look more into it. Luckily I'm not renting it, it was just a symbolic purchase with permanent warranty from their side (no monthly fees attached to the router, it gets replaced when needed).
      A few years ago I went with a Ubiquiti Secure Gateway router and an access point as I was a bit fed up with the consumer routers. It is a great device, but it is a bit underpowered. I bought it just before Ubiquiti came out with the DreamMachine which can do 3.5 Gbps DPI, whereas mine can only reach 85 Mbps; and just before my ISP installed FTTH and bumped me from 80 Mbps DSL to 300 Mbps.
      My old router went to my inlaws, to replace their failing router. But now they need a new solution (my old one is also failing at their place). However, for them we would just go with a nice Asus AI mesh solution like I got my parents. I was tempted of passing down my Ubiquiti, but it would get too expensive: I would need to get them a second access point, a switch (the Ubiquiti Security Gateway has no built-in switch) and then get an access point and router for me - or I would have to go back to a consumer router. So now just getting them the Asus mesh, and I'll replace my router when necessary.
        Yes, it became so much easier for ISPs to rent you equipment now that everything at home uses wireless 'internet' and nobody wants to bother understanding how the 'magic' actually works.
          Originally posted by TransformX View Post
          The plan is to run Type-1 hypervisor and host whatever I need as virtual machines. Considering those VMs are mostly going to be 'appliances' their footprint ought to be minimal, bare bone (server) linux and the platform/server/application installation.
          Clear, you should be good to go then
            No fiber yet, but the computer is up and running!
            Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
              So, the bad news: a lightning storm partially fried my Lancom 2310P (at least two ports died, no longer trust POE).
              The kind of good news: my wallet stepped in and bought a Mikrotik RB4011 with AdGuard home docker to save the day.
                I have a dead RB4011 (replaced with hAP AC3).
                  ROFL, nice.
                    I just ended up ordering two Asus TUF3000v2 routers to set up a mesh at my in-laws. It was quite a good offer and will suffice for them, although I'm annoyed because last year I ordered two Asus RT-AX92u for the same price (and those have higher specifications for wifi and usb, only thing the new ones have over them are 2.5GBit wan and teaming support). So it is beginning to look like features/developments have stalled, just like we are seeing with computers and mobile phones.
                    At home, it is tempting to upgrade, but I have no need to do so. My Unify USG is doing very well (stable, fast enough), I only cannot enable deep package inspection as that would limit my throughput to 85Mbps; and my DLink switch (DGS-1216) is now 12 year old and still going strong (a 16 port professional smart switch which I got in an amazing offer, and it still is covered by warranty!).
                    So for now my intention is to upgrade one computer next year, when the next generation of cpus comes out, and delegate the current computer as a file server - to finally make order with that. It has 1 m2 slot and 6 sata slots (it also has the obsolete standard sata express), so enough for quite a number of disks, and if necessary a sata controller is easily added (4 pcie slots). It also has 2 PCI slots, one of which is used for a PCI SCSI controller to which a scanner is connected, which would be much better positioned where I would plan to install it. My recent sudden loss of my phone (mainboard failure) made me realize I don't have a good enough file storage/backup mechanism, it is too much to maintain with manual copies and syncs with laptops, cameras and phones.
                    Best is to just get a dedicated system that takes care of it. I have the plans on how/what to organize it all, but need the hardware to implement it.
                      Ubiquity has launched a new USG Express, which is a router with wifi point (no switch). Still, would have been a potential option at my inlaws... But the Asus routers were already bought, are installed and work very well. The Asus routers even manage to have a good wireless backhaul connection, which I did not expect given their locations. Still, we repurposed a network cable in order to have a wired backhaul (with the wifi as backup).
                      Probably the Unify router would get more expensive as in my inlaws' setup we really need 2 switches and 2 access points. It may be an interesting upgrade for me, as it could later be repurposed as a wifi access point, but the USG I have is still going strong, as is my access point and it seems pointless to upgrade if it does not add much (it does not have deep packet inspection, something my current USG has but at the expense of bandwidth: it then drops to 80 Mbps).
                      However, I've read that it may be possible in Orange to add your own GPON (and there are SFP+ GPONs for this purpose), so in that case the more expensive Dreamrouter would be an ideal option to replace both the USG and the operator's router. Fun to search those network things, but pointless to change if it all works fine...
                        I managed to revive my RB4011 using netinstall from Linux. Ports were not giving out DHCP and I turned off the lights in webfig so it appeared dead.
