Dual ISP's logging on problems
  • Dual ISP's logging on problems
    I'm now with ukonline adsl and virgin cable. This really confuses the Murc login process and it keep throwing me off saying I'm not logged in. I've managed to get in using a vpn connection.
    Any chance of a fix.
    Weather nut and sad git.
    My Weather Page
    I use 2 ISPs (one at home, another at work), and have never had any problem. Always logged in, no matter where I am at.
    You do have your cookies on, and are not clearing them?
    Core2 Duo E7500 2.93, Asus P5Q Pro Turbo, 4gig 1066 DDR2, 1gig Asus ENGTS250, SB X-Fi Gamer ,WD Caviar Black 1tb, Plextor PX-880SA, Dual Samsung 2494s
      Two at the same time into one router.
      At the moment it's set to line speed so I presume it keeps swapping between the two.
      Only Murc and one other forum do I have a problem with.
      My Weather Page
        May have solved it by using load Balancing rules.
        My Weather Page
          What are you using TP? And are you getting any benefit from the dual ISPs?
          FT.
            Ukonline for adsl and Virgin media cable. Can't get above 8mb on adsl in theory I should be on 20mb with cable but pretty sure I'm not. Got to log directly onto the router and see what it thinks it connecting at. Too busy at the moment though.
            My Weather Page
