Dogbert, I definetly think the best course of action would be to get say a 8500 and a good tvcard.. together that should be under $200. You'd be very happy with the results
Graphic card recommendation
Wikipedia and Google.... the needles to my tangent habit.
________________________________________________
That special feeling we get in the cockles of our hearts, Or maybe below the cockles, Maybe in the sub-cockle area, Maybe in the liver, Maybe in the kidneys, Maybe even in the colon, We don't know.
I would ask terratec again - I can't believe there is no NTSC version of this card (I guess you use NTSC in israel?)
Great - then I'd get a Cinergy 400 TV, if btwincap and dscaler won't work better.
Terratec lists http://www.5exits.co.il/ and http://www.halilit.co.il/ on their "where to buy" page for israel.
Another program worth to try with your BT878 based card would be MoreTV - that's the program I like the most. Unfortunately it's only available in german, but the usage should be pretty self-explanatory nevertheless.
MoreTV is a really small program <<500KB and doesn't need any driver installed at all, cause it talks to the BT878 directly.Last edited by Indiana; 27 August 2002, 09:41.
Is it used for watching TV or for capturing?
Can you tell us more?
It's only for viewing TV, but there it is MUCH better than Hauppauges crappy WinTV32/2000 applications. It has none of the overlay problems you'll get with WinTV32 on most gfxcards, has integrated great and very speedy Teletext, doesn't need any drivers, works flawlessly under Win98, Win2000 and WinXP, even has a great quality RGB mode (for those who still have problems with overlays, e.g. on dual monitor systems with cards with only one hardware overlay), can decode certain encrytion systems with a CPU >1GHz, is a small and lean application,....Last edited by Indiana; 28 August 2002, 15:26.
The Pinnacle does have the BT848 or 878 on it (depending on the model), but that's NOT the tuner, it's just for decoding the analog PAL/NTSC/... signal. These cards have an additional tuner chip on them, Hauppauge uses a Philips one, but even there, there are several different chips/revisions used.
Just try MoreTV if you only want to view TV, it needs no drivers, has presets for several cards you can try and if none of these work you can still choose between many different tuner types/manufacturers and you should be able to get it to work nevertheless.Last edited by Indiana; 29 August 2002, 15:41.
Sorry, my bad
Just tried MoreTV, and it's great
The simple TV application I always wanted.
