XGI first test
  • bsdgeek
    • Feb 2002
    • 1543
    THG preview. Looks great in some cases, abysmal in others.
    • gangster
      • Aug 2003
      • 316
      Originally posted by bsdgeek
      http://www.tomshardware.com/graphic/20031107/index.html
      It's wild seeing that much variation.
      P4b@2.7, AOpen ax4spe max II, 4X Parhelia 128 with Zalman zm80c and fan -or- ATI Radeon X800GTO, 1024mb.
      • Helevitia
        • 6628
        Hopefully it can be chalked up to early drivers that need to be tweaked.
        • gangster
          • Aug 2003
          • 316
          I agree. I would be more than willing, even look forward to, trying a new card unless the price was astronomical.
          • Helevitia
            • 6628
            They are saying $300 for there top of the line card. that is for the DUOV8 or whatever it is called.
            Dave
            • gangster
              • Aug 2003
              • 316
              Dave
              Surely they realize that with only 2 major card makers now a third could be an incredible success if it's done first class, imo.
              • Indiana
                • Mar 2000
                • 2410
                My guess would be cheating drivers
                The fact that all games are forced to a bilinear filter while ONLY the one most used app to test the filtering is rendered with correct trilinear very strongly hints into this direction: i.e. they made the driver detect the test prog and then use trilinear and force bilinear in all other cases - maybe they thought they'd get away with this.
                Considering the bilinear filtering and the BAD texture-quality (now that's much worse than even the worst NVidia-cheat driver ever has gone) renders the benchmark results invalid and doesn't shed a good light on the card: if performance is only at the level with this reduced texture details and as it looks reduced rendering precison, plus a forced bilinear filter, then the card wil most likely only perform at Radeon9600Pro level with full detail.
                And then it's simply much too expensive...
                A bit "strange" or should I say suspicious is also the fact, that the card does fare the best in the most used benchmarks and delivers abysmal results whenever custom benchmarks are used - sounds a lot like cheating to me...
                My System
                German ATI-forum
                • gangster
                  • Aug 2003
                  • 316
                  yup
                  • knirfie
                    • Mar 2002
                    • 789
                    Does beta hardware with beta drivers say anything to you?
                    Main Machine: Intel Q6600@3.33, Abit IP-35 E, 4 x Geil 2048MB PC2-6400-CL4, Asus Geforce 8800GTS 512MB@700/2100, 150GB WD Raptor, Highpoint RR2640, 3x Seagate LP 1.5TB (RAID5), NEC-3500 DVD+/-R(W), Antec SLK3700BQE case, BeQuiet! DarkPower Pro 530W
                    • Admiral
                      • Aug 2000
                      • 3125
                      You might let them get away with the bilinear filtering though the custom versus preset benchmarks look mighty suspicious as Indiana mentioned.
                      Let's take UT2003, it does very well in Antalus, better than a 9700 Pro and closely trailing a 9800 XT, yet when you bench it in the custom recorded Magma and Inferno demos, it falls to almost half of what a 9700 Pro can do.
                      • bsdgeek
                        • Feb 2002
                        • 1543
                        #26
                        It would have to be some extreme cheating for that much of an increase, it's like the 2nd chip isn't even on in some cases.
                        • K6-III
                          • Dec 2000
                          • 2253
                          #27
                          I would wait for final drivers and hardware before throwing around cheating allegations...
                          Let us return to the moon, to stay!!!
                          • TransformX
                            • Sep 2003
                            • 4946
                            #28
                            It's not like Tom can't be bought... Maybe they just didn't pay enough to *fix* all the benchmarks
                            "Hey, I told you those custom benchmarks'll cost you an extra..."
                            • gangster
                              • Aug 2003
                              • 316
                              #29
                              somethings still odd though, the variation seems to be from an optimization or just plain crappy drivers altogether and that seems odd to.
