I personally only draw air out of the case, I don't "push" any in from the front. Over pressurizing the case can cause hot pockets in the lower part of the case from turbulence around the cards.
On the other hand, a side mounted fan over the cpu is good because this is adjacent the exhaust fan near the cpu and is like cross-flow ventilation. I wish I had a case with this option.
I use all the rear fans possible and because the fans are on the back and not the front, things are quieter.
This also seems to reduce dust in the case as there are no fans near the floor.
