help on setting up a webboard&SMTP server
  • Sasq
    Administrator
    • Jan 2001
    • 4633
    just a dial in vpn and let them access as normal. Optionally speak with the ISP tech department and see if they can sort something.
    Juu nin to iro
    • Kurt
      • Feb 2000
      • 1839
      If they get cellular signal, is GPRS not an option?
      • Belwarrior
        • Nov 2000
        • 888
        GPRS was too expensive and so was Wireless Lan..
        we are a shoe string budget as all our money is from research grants and current economical state is not helping us
        Life is a bed of roses. Everyone else sees the roses, you are the one being gored by the thorns.
        AMD PhenomII555@B55(Quadcore-3.2GHz) Gigabyte GA-890FXA-UD5 Kingston 1x2GB Generic 8400GS512MB WD1.5TB LGMulti-Drive Dell2407WFP
        ***Matrox G400DH 32MB still chugging along happily in my other pc***
        • Kurt
          • Feb 2000
          • 1839
          If you're willing to put in a bit of sweat there's probably a software solution for you. You should see whether you can leave all the mail on the University server and download a copy on your machine, then allow for VPN access to it. You'll need either a fixed IP or a DynDNS account for both sites. You need to make sure your ISP allows for VPN traffic on the kind of access you have.
          Expect the phone bill to rise though as VPN is cutting bandwith, unless you choose not to use encryption (so you shouldn't loose too much bandwith from the 9.6Kbps...).
