Umf just had look at the schematics,
the relays are spdt type (single pole double throw).
if you want to have forward/reverse function you will need to use a split power supply (+6v, gnd,-6V for example) or replace the relays with dpdt (double pole double throw)type.
-pulse mode only energizes the relay when you are pressing the remote button
-toggle mode allows one press for on/one press for off for each channel.
if you use a regular motor then you won't need th motor controller.
actually if you know anyone handy with electronics, you have a full schematic for the receiver to build it yourself! (you don't need to wait for the kit)
