the sound of silence
  • az
    • Feb 2001
    • 9336
    Don't forget though that you'll still need airflow for your voltage controllers, etc. (there are lots of parts on a mainboard that get quite hot), even if you watercool your HDDs. Though I think a decent power supply should suffice (but don't take my word for it).
    • Paddy
      • Mar 2000
      • 6067
      I would still have a 120mm fan running 'silent' just to ensure airflow through the case. I would have the exhause fans under the rad.
      • Taz
        • Nov 1999
        • 1393
        Originally posted by Paddy
        Can you recommend any?
        What suppliers, or water cooling kit
        • Paddy
          • Mar 2000
          • 6067
          both
          • Taz
            • Nov 1999
            • 1393
            I'm no watercooling expert so I'll leave the suggestions of what to buy to other people
            From those suppliers Kustom PC's are easily the most helpful/reliable but unfortunately their watercooling range is a bit limited. Marci at Over-Clock seems a decent enough chap and they have a far greater selection so give them a try.
            • Paddy
              • Mar 2000
              • 6067
              Cool
              Essentially, I want to know if the more well known kit (e.g. DangerDen, Black ICE etc.. ) is any better than the less well known stuff...
