HELP!!!! Remote access how to do it?
  • Fat Tone
    • 7579
    When I say *my* ISP. I mean NTL, at home. They see that (VPN) as business use...
    FT.
    • William
      • Jun 2002
      • 283
      If the office server is running windows 2000 server or later, then it's got VPN built in. There are some good guides on the MS website about how to enable it.
      MURC COC Minister of Wierd Confusion (MWC)
      • Byock
        • Jul 2000
        • 2328
        Very easy to do. couple question, what server os? 2003?
        Does the firewall allow connections to it? easiest solution is to enable remote desktop in My Computer properties, forward port 3389 to the server, log in using Remote desktop.
        "I dream of a better world where chickens can cross the road without having their motives questioned."
        • Oboy
          • Feb 2000
          • 552
          I thank you all for the ideas. Now I just need to get this software to work in XP. Looks like upgrade time. hehe wife not going to like that!
          Oboy
          Time to make the wafers!
          Oboy Inside!
          intel P4 2.26 @ 2.957Ghz
          "Life isn't like a box of chocolates...it's more like a jar of
          jalapenos. What you do today, might burn your ass tomorrow."
          • Oboy
            • Feb 2000
            • 552
            Well I just ordered the software upgrade for her office. They where kind to me and will be spreading the charges over the next 12 months, SWEET!!
            So back too my question, the software is of the medical type and what is needed is for someone she has working for her, be able to have access and run the software from the server, remotely so they can fill out the paper work to file insurance clams. How I would like to set this up is have them phone the server, give a PW and go from there. Can this be done in a secure way? The phone number is not published. I don’t won’t to do this if there is a chance that someone can get personnel info by hacking into the server. I will have Zone Alarm, (or something you all recommend) installed.
            Thanks again for your help!
            Oboy
            Oboy Inside!
            • Wombat
              • Aug 2000
              • 9498
              At this point, if it's medical, HIPAA may apply to you, and you really should talk to an expert.
