Need a tester using Opera
  • TnT
    • 1644
    Originally posted by az
    Have a post on the Opera forums, maybe they can figure out what's wrong and either tell you it's a bug in Opera or your code, and maybe help you code around it
    Shouldn't take you much time, they do all the work
    Thanks for the tip AZ, got my answer at the end of the day.
    It is a known bug. Here's the workaround:
    Code:
    <div class="blah" style="position: fixed">
       <div style="position: relative">
            absolute positioned divs
       </div>
    </div>
    If y'all want to check it out now:
    Gigabyte GA-K8N Ultra 9, Opteron 170 Denmark 2x2Ghz, 2 GB Corsair XMS, Gigabyte 6600, Gentoo Linux
    Motion Computing M1400 -- Tablet PC, Ubuntu Linux
    "if I said you had a beautiful body would you take your pants off and dance around a bit?" --Zapp Brannigan
    • PAugustin
      • Nov 2000
      • 700
      Now works perfectly on Opera 8.01. I can click the menu and the submenu shows up.
      System : ASUS A8N SLI premium, Athlon 64X2 3800+, 2Gb, T7K500 320Gb SATAII, T7K250 250Gb SATAII, T7K250 250Gb ATA133, Nec ND-3520, Plextor PX130A, SB Audigy 2, Sapphire Radeon X800 GTO, 24" Dell 2407WFP.
