Water cooling for the masses.
  • Wombat
    • Aug 2000
    • 9498
    #46
    Originally posted by borat
    anyway, subsequently purchased an MSi neo2platinum motherboard with a amd 64bit venice 3200+. Installed the aquamini and it fired up first time. Have not had time to overclock but at stock speeds its running between 35C and 38C depending on load with a minimum fan speed. For reference the case is open at the moment and the thermometer on the chipset is returning 32C so the processor is pretty close to ambient i would say. will overclock this evening and post results.
    That's pretty high. My Venice 3000 is OCed 30%, and with my xp90 (and low-rpm Panasonic fan) it's 35-37C.
    • ZokesPro
      Serial Murcerer
      • Sep 2000
      • 8325
      #47
      Is this your heatsink?
      Titanium is the new bling!
      (you heard from me first!)
      • Wombat
        • Aug 2000
        • 9498
        #48
        Yup, works quite nicely. Even better than it's brother the xp-120.
        • ZokesPro
          Serial Murcerer
          • Sep 2000
          • 8325
          #49
          Indeed! What kind of cooling do you have in you case? Seems like your setup works better the the aquamini, that's for sure.
          Last edited by ZokesPro; 23 September 2005, 16:52. Reason: cause I said the same thing
          • borat
            • Jul 2001
            • 1035
            #50
            that is impressive wombat, have had a quick play with o/cing it now and just hit 2.4 - temperature 39 degrees under load. very impressed with these venice chips.
            is a flower best picked in it's prime or greater withered away by time?
            Talk about a dream, try to make it real.
