home network
  • DentyCracker
    • Jan 2000
    • 2023
    #31
    OK got it working again under 2k. Just a matter of setting up DNS properly
    [size=1]D3/\/7YCR4CK3R
    Home: M1 Mac Mini 8GB 256GB
    Frontdesk: Beelink T4 8GB
    • ageedoy
      • 33
      #32
      i think there's something up with my ethernet card in pc#1 (server). pc#1 and pc #2 are connected to the hub. The activity light is always on for pc#2, but doesnt go on for pc#1. the network worked through netbeui, but doesnt work for tcp/ip. any solutions?
      • paul
        • 238
        #33
        you sure that's not the link led? On mine,
        cable nic: both lit
        hub nic: link lit
        abit kt7-raid athlon 1ghz quantum 20.4gb - 7200 + wd 200bb - 7200 rpm UDMA100-
        g400 max-
        256MB pc133 sdram - sblive value 3.0 - 4 Boston Acoustics A40's - 3com 3c905b-tx - cable access - winME
        dx7.?- V3 steering wheel/pedals - MS sidewinder PRO
        Kensiko (Netpointe) scrolling mouse
        • Raptor^
          • Dec 1999
          • 268
          #34
          Sometimes Win9xs networking goes fubared.. have you tried removing the TCP/IP protocol from both machines and adding it again.
          When you add it again remember to assign the 2 network cards that make up your local network IPs that can't be routed onto the internet (192.168.0.X works for me).
          • Raptor^
            • Dec 1999
            • 268
            #35
            Oh yeah, you might as well remove netbeui and IPX for the moment too, they are pretty useless and will just confuse the main issue, which is whether your TCP/IP link is working or not
            • ageedoy
              • 33
              #36
              paul- the link lights are lit for both pcs on the hub. the activity light is lit only for pc#2 (client).
              raptor^- ive taken out netbeui and ipx on both pcs. both are also running on 192.186.0.x ips.
              • paul
                • 238
                #37
                The activity light should only be solid for the cable modem nic.
                If another nic's activity LED is lit, it's f-- up.
                g400 max-
                • Mark F
                  • 979
                  #38
                  Do you have the cable modem hocked to your hub with a patch or X-over cable? Is in a regular port or an up-link port?
                  Makes a big difference.
                  If it's in an up-link port you need a patch cable (what it was probable hocked to your PC with).
                  If it's in a regular port you need a cross-over cable (the send and transmite lines are crossed)
                  Let up know how you had it hocked up.
                  Mark F.
                  ** Any one know how to get (force) a router to release and renew? It keeps showing all zeros for WAN IP, gateway, etc **
                  OH NO, my retractable cup holder swallowed a CD
                  Mark F. (A+, Network+, & CCNA)
                  OH NO, my retractable cup holder swallowed a DVD...
                  and burped out a movie
                  • paul
                    • 238
                    #39
                    the modem should be directly to the nic, not the hub.
                    On the hub, 2 ip's will be needed
                    g400 max-
                    • ageedoy
                      • 33
                      #40
                      comp #1 has 2 network cards- 1 pci and 1 isa. th cable modem is hooked to the pci ethernet card and the isa is connected to the hub (linksys broadband network bridge model # hpes03) with "premium category 5 utp patch cable" that is 3 feet long.
                      comp#2 has a linksys home network phonline link card that is hooked to upstairs phone outlet. the connection is completed with a line from another phone outlet to the hub. i know the connection works because it worked through netbeui.
                      • mj12
                        • 214
                        #41
                        Ok, sorry to jump into this in the middle. Please tell me exactly what internet sharing solution you are using. Sygate, ICS, nat32, etc. OS's installed and how they are wired. And do a "ipconfig /all > ip.txt" from a command prompt without the quotes and post the info here too.
                        Asus K7V
                        Athlon 700
                        128mb PC133 HSDRAM
                        Matrox Millennium g400max
                        Adaptec 2940U2W
                        IBM 9gb U2W
                        Plextor 8/20 cdr
                        Diamond MX300
                        3com 905b-tx
                        • ageedoy
                          • 33
                          #42
                          comp #1
                          -win98se
                          -isa ethernet card to linksys homelink broadband network bridge through premium category 5 utp patch cable
                          -pci ethernet card to cable modem
                          comp #2
                          -win98se
                          -pci linksys homelink card connected to linksys bridge through phonelines.
                          i've tried connecting them directly using the patch cable w/o connecting to the bridge before and i got the same problem. id prefer to use sygate, but if i can get wingate or nat32 to work, i wouldnt mind using those.
                          COMP #1
                          Windows 98 IP Configuration
                          Host Name . . . . . . . . . : C******-A.stcla1.sfba.home.com
                          DNS Servers . . . . . . . . : 24.1.4.14
                          24.1.4.12
                          Node Type . . . . . . . . . : Broadcast
                          NetBIOS Scope ID. . . . . . :
                          IP Routing Enabled. . . . . : No
                          WINS Proxy Enabled. . . . . : No
                          NetBIOS Resolution Uses DNS : No
                          0 Ethernet adapter :
                          Description . . . . . . . . : PPP Adapter.
                          Physical Address. . . . . . : 44-45-53-54-00-00
                          DHCP Enabled. . . . . . . . : No
                          IP Address. . . . . . . . . : 192.168.0.1
                          Subnet Mask . . . . . . . . : 255.255.255.0
                          Default Gateway . . . . . . :
                          Primary WINS Server . . . . :
                          Secondary WINS Server . . . :
                          Lease Obtained. . . . . . . :
                          Lease Expires . . . . . . . :
                          1 Ethernet adapter :
                          Physical Address. . . . . . : 44-45-53-54-00-01
                          DHCP Enabled. . . . . . . . : Yes
                          IP Address. . . . . . . . . : 0.0.0.0
                          Subnet Mask . . . . . . . . : 0.0.0.0
                          DHCP Server . . . . . . . . : 255.255.255.255
                          2 Ethernet adapter :
                          Description . . . . . . . . : AOL Adapter
                          Physical Address. . . . . . : 44-45-53-54-61-6F
                          3 Ethernet adapter :
                          Description . . . . . . . . : AOL Dial-Up Adapter
                          Physical Address. . . . . . : 44-45-53-54-61-70
                          IP Address. . . . . . . . . : 192.168.0.125
                          4 Ethernet adapter :
                          Description . . . . . . . . : The PCI Fast Ethernet Adapter.
                          Physical Address. . . . . . : 00-E0-29-47-1A-09
                          IP Address. . . . . . . . . : 24.7.83.***
                          Default Gateway . . . . . . : 24.7.83.1
                          DHCP Server . . . . . . . . : 24.0.0.70
                          Lease Obtained. . . . . . . : 02 14 00 3:23:16 PM
                          Lease Expires . . . . . . . : 02 21 00 3:23:16 PM
                          5 Ethernet adapter :
                          Description . . . . . . . . : Realtek RTL8019(AS) ISA PnP Ethernet Adapter.
                          Physical Address. . . . . . : 00-00-E8-86-5D-75
                          IP Address. . . . . . . . . : 169.254.133.149
                          Subnet Mask . . . . . . . . : 255.255.0.0
                          Lease Obtained. . . . . . . : 02 14 00 3:23:43 PM
                          COMP #2
                          Host Name . . . . . . . . . : NANAKI
                          DNS Servers . . . . . . . . : 192.168.0.2
                          NetBIOS Resolution Uses DNS : Yes
                          Description . . . . . . . . : AMD HomeLan Adapter
                          Physical Address. . . . . . : 00-20-78-B0-46-1D
                          IP Address. . . . . . . . . : 192.168.0.2
                          Default Gateway . . . . . . : 192.168.0.2
