No video signal on a cold boot with ASUS A7V, need help
  • Ovi
    • Mar 2000
    • 321
    Jackzod:How did you disable auto-restore? Did you do it thru Msconfig?
    Cheers
    Ovi
    • jackzod
      • Oct 1999
      • 204
      to disable it you have to right click on my computer icon.
      click on properties --->performance tab--------->click on system files--->then go to the last tab (don't know the name, i'm using a french os, should be something like debugging or so), there you have a lot of option, click on the bos in front of "disable auto-restore" and reboot after.
      That should do it
      Athlon64 4800+
      Asus A8N deluxe
      2 gig munchkin ddr 500
      eVGA 7800 gtx 512 in SLI
      X-Fi Fatality
      HP w2207
      • Ovi
        • Mar 2000
        • 321
        Oh I remember it now
        Thanks Jackzod
        Cheers
        Ovi
        • jackzod
          • Oct 1999
          • 204
          You're welcome
          Athlon64 4800+
          Asus A8N deluxe
          X-Fi Fatality
          HP w2207
