G400MAX beatan by a TNT2U in Q3??????????
  • Hex
    • Jan 2000
    • 18
    #31
    I dont know if this is going to be of any help. But i ran Wcpuid and have posted the results bellow. Anything not look right for an AMD Athlon system?
    [ WCPUID Ver.2.7a (c) 1996-2000 By H.Oda! ]
    Processor 1 : AMD Athlon (Model 1) / 6C84107A
    Platform : Slot A (SC242 Connector)
    Vendor ID : AuthenticAMD
    Type ID : 0 (0)
    Family ID : 6 (7)
    Model ID : 1 (1)
    Stepping ID : 2 (2)
    Brand ID : 0 (0)
    Clock Frequency
    Internal : 704.92 MHz
    External : 201.41 MHz DDR
    Multiplier : 3.5
    L1 I-Cache : 64K
    L1 D-Cache : 64K
    L2 Cache : 512K Byte
    L2 Speed : 1/2 H4 (1/2 H4, 1/2 S4)
    MMX : Supported
    SIMD : Not Supported
    3DNow! : Supported
    Machine : IBM PC/AT
    Version : Windows 98 Version 4.10.2222 A
    F.Flags : C0C1F9FF 80000006
    I@PCP : 00000000 00000000 00000000 00000000
    A@EXT : 0408FF08 FF18FF10 40020140 40020140
    : 00000000 41004100 02002140 00000000
    A@Cx10 : 00160604 CB02810F 60000001 5A1421D5 222402DD
    A@Cx15 : 08601000 00000000 00000000 E0000018 F8000800
    A@Cx1Z : 08000000 1CE20223 000A0000 00000000 00000001
    (Processor 1)
    << Standaed & Extended Feature Flags >>
    Floating-point unit on-chip (FPU) : Supported
    Virtual Mode Extension (VME) : Supported
    Debugging Extension (DE) : Supported
    Page Size Extension (PSE) : Supported
    Time Stamp Counter (TSC) : Supported
    Model Specific Registers (MSR) : Supported
    Physical Address Extension (PAE) : Supported
    Machine Check Exception (MCE) : Supported
    CMPXCHG8 Instruction (CX8) : Supported
    On-chip APIC Hardware (APIC) : Not Supported
    Fast System Call (SEP) : Not Supported
    Memory Type Range Registers (MTRR) : Supported
    Page Global Enable (PGE) : Supported
    Machine Check Architecture (MCA) : Supported
    Conditional Move Instruction (CMOV) : Supported
    Page Attribute Table (PAT) : Supported
    36-bit Page Size Extension (PSE36) : Not Supported
    96-bit Processor Number (PN) : Not Supported
    MMX Instructions Extensions (MMX+) : Supported
    MMX Instructions (MMX) : Supported
    Fast floating-point save and restore (FXSR) : Not Supported
    Streaming SIMD Extensions (XMM) : Not Supported
    3DNow! Instructions Extensions (3DNow!+): Supported
    3DNow! Instructions (3DNow!) : Supported
    (Processor 1)
    << Cache Info. >>
    [L1 Instruction TLB]
    2-Mbyte/4-Mbyte Pages, fully associative, 8 entries
    4-Kbyte Pages, fully associative, 16 entries
    [L1 Data TLB]
    2-Mbyte/4-Mbyte Pages, 4-way set associative, 8 entries
    4-Kbyte Pages, fully associative, 24 entries
    [L1 Instruction cache]
    64K byte cache size, 2-way set associative, 64 byte line size, 1 line par tag
    [L1 Data cache]
    [L2 Unified cache]
    512K byte cache size, 2-way set associative, 64 byte line size, 1 line par tag
    [L2 Instruction/Unified TLB]
    2-Mbyte/4-Mbyte Pages, Off, 0 entries
    4-Kbyte Pages, 4-way set associative, 256 entries
    [L2 Data TLB]
    << AGP Chip set Info. >>
    Chip-set Device : AMD-751
    Chip-set Revision : 23
    AGP Revision : 1.0
    AGP Operations : Enable
    Data Transfer Rate
    Supported : 1x 2x
    Current : 2x
    Side band addressing : Enable
    Aperture Size : 256MB
    70061022 22100006 06000023 00804000
    00000000
    00100002 0F000203 00000302 00010005
    00020000 00000000 00000000 00000000
    "There's no such thing as a stupid question, just stupid people"
    [This message has been edited by Hex (edited 09 January 2000).]
    • Fyrespray
      • Nov 1999
      • 57
      #32
      Ok we have both taken Trilinear off and gone to bilinear the results are now
      Me :59.6 FPS
      Hex :54.0 FPS
      well we are certainly getting closer but my system in only a celery 550 whereas his is an Athlon 700 so it still looks like something isn't right, lets face it I should not be beating his scores
      Fyrespray
      Celery 366 @ 550,Abit BM6, 128Mb PC100 Ram, G200 8Mb, AWE64 Gold, Win98SE.
      Fyrespray
      http://www.ukgamer.com
      http://www.ukgamer.com/columns.php3?author=9
      • Rags
        • 4052
        #33
        I don't know what else to try except what I have already suggested to you....which TurboGL are you using?
        Maybe when Greebe gets online, he can help you tweak that properly.
        Rags
        • Hex
          • Jan 2000
          • 18
          #34
          Ok. Im beginning to think that maybe my system as a whole is running slower than it should be. Can someone recomend me a good bit of benchmarking software (preferably free) that i can test my system as a whole, Not just games, with and post the results back.
          ----Hex
          • Rags
            • 4052
            #35
            Stay tuned, you will get some help in a few minutes
            • Hex
              • Jan 2000
              • 18
              #36
              OK. Cheers.
              ----Hex
              • paulcs
                • Jan 2000
                • 3098
                #37
                This is really weird. I just noticed that when I enter the game using the test config and the G400, the game is set to trilinear filter as it should be. However, when I use an identical copy of the config, and start the game with the TNT2 machine, it defaults to *bilinear* filtering.
                I have a separate, completely segregated, clean copy of the config file I downloaded, and I have reloaded it (and my CD code!) several times, in both machines, with the same results. This makes my previous TNT2 numbers invalid, as I assumed the game would open with trilinear filter, because the config is set up that way.
                Here are some new numbers with the texture slider back up to Max and bilinear filtering forced manually on the TNT2 Ultra:
                G400/PIII 600/Trilinear: 40.9
                G400/PIII 600/Bilinear: 58.6
                TNT2U/PIII 500/Trilinear: 56.7
                TNT2U/PIII 500/Bilinear: 57.5
                Trilinear filtering is the killer for me. My Max takes a hit of about 30% going from bilinear to trilinear filtering. My TNT2 Ultra takes a hit of less than one frame per second.
                Either the Max has a serious problem with trilinear filtering on my system, the TNT2U is particularly good with this setting, or nVidia is fudging somehow.
                If the latter is true, this is not a valid test.
                paulcs@flashcom.net
                • Rags
                  • 4052
                  #38
                  Hi Paul,
                  The reason the TNT2 doesn't show a huge decrease is because it doesn't really use trilinear filtering, it will run with trilinear set, and will show some improvement, but for the most part it is not working. In 800X600 with all the goodies on, the textures won't fit into the video memory with trilinear set to enabled, that is why the G400 shows a performance hit, it is using AGP texturing.
                  Rags
                  • paulcs
                    • Jan 2000
                    • 3098
                    #39
                    Well, then you were right and the TNT2 is fudging.
                    As far as the science of this goes, we are measuring the performance hit the G400 takes using trilinear filtering; on the other hand, we are measuring how well nVidia fudges trilinear filtering. The comparisons are not at all valid using this setting.
                    NVidia bastards.
                    paulcs@flashcom.net
                    • Greebe
                      • 8555
                      #40
                      OK I set my Athlon to 700 (1:2 latency) PD 5.41 TGL, MSI6167 MB, using your config file...
                      trilinear = 54.8
                      bilinear = 67.1
                      • Fyrespray
                        • Nov 1999
                        • 57
                        #41
                        We originally had that problem too, if you change the name of r_lastvalidrenderer in the cfg file between g400 and the nvidia entry (can't remem it offhand) that should solve the problem of it resetting it to defaults. We think we might have gone someway to finding out what is happening though, this is a shot of memory benchmarks from Hex's machine, and mine. My machine seems to be beating his which is definetly not right. Any Athlon owners out there have any ideas ???
                        we did this benchmark with sisoft sandra available <a href=http://download.cnet.com/downloads/0-10102-101-915435.html>Here</a>
                        <IMG SRC="http://www.fyre.nildram.co.uk/benchmarks.jpg"">
                        This is relly confusing us now please somebody help
                        ok i know the jpg looks a bit shitty but hey i figured you don't really care about eye candy and nicly lined up boxes with a benchmark screenie
                        Fyrespray
                        Also thanks for all the help you have been giving us so far its definetly keeping us sane
                        [This message has been edited by Fyrespray (edited 10 January 2000).]
                        Fyrespray
                        • Rags
                          • 4052
                          #42
                          The memory performance of the Athlon motherboards cannot compare to the performance of the Intel 440BX chipset, that is why that particular benchmark is awry.
                          Rags
                          • Greebe
                            • 8555
                            #43
                            I'll second that Rags!
                            • Fyrespray
                              • Nov 1999
                              • 57
                              #44
                              Ok but it still looks a bit close to an AMD K6-3 500, what sort of benchmarks would you suggest we take to compare to see if it is his machine that is not configured properly in some way??
                              Fyrespray
                              Fyrespray
                              • Greebe
                                • 8555
                                #45
                                Well I decided to OC me Max and reran the tests...
                                bi =79.2
                                tri =65.2
                                What does his score on the CPU test in Sandra?
                                I'll lower mine for the same...
                                Designer of the first commercial Athlon mod.
                                Anyone up for an Eclipse'd Athlon? Email me (epc@netdirect.net) for more information
                                3000 mips, 1.172 gflops @ 900 mHz 1:3 latency
                                CPUmark99 75
                                FPU Winmark 4890
                                3Dmark 99 Max (8x6 16, 16, triple) PD5.41
                                8000
                                15181
