I got it up and running beautifully at work, but I'm having troubles at home.
Since I'm on dial-up I use it to cache WU's and then access them with the client. Lately I've been getting the following message:
Can anyone tell me what the problem is??
thanks,
amish
"The Server has already received theis result from you; your totals will be adjusted to eliminate this duplication"
thanks,
amish
