Thanks for the comment Frank. I agree, it does seem low. There's nothing else on that channel (i.e., it's the only device on the LVD channel). Is your 70 MBS on an 2940U2W adapter? Any suggestions on what to try to bump it up?
Yes. I recently upgraded from a 2940U2W to 29160, but the 70mbps is consistent on both. This is on a PIII @ 840MHz.
What OS are you using? I noticed a substantial performance boost once I installed W2K SP1, compared to Win98 SE. (Something to do with the fact that command queueing is supported under W2K but not 9x, from what I've been told.)
Frank, thanks for pointing out to me the obvious. My score is from WinMe. I should have indicated that in my original post. Out of curiousity, I did manage to get a few more MB/s by playing around with my PCI latency, but hardly worth the trouble.
And Guru, I'm surprised it's taken this long for someone with a RAID rig to post! Nice score.
Come on all, let's see some more! It's nice to see what's out there and what one can expect from the various hard drive set ups.
<font face="Verdana, Arial, Helvetica" size="2">Originally posted by Electric Amish: I get BSOD's every time I try to run HDTach.
amish</font>
This is a known problem with HD Tach ver 2.61. To eliminate this, you'll have to disable auto-insert notification for your CD Drive, or use a previous version of HD Tach.
Cheers
Ovi
Just got my drives today and this is my Atto score out of the box for my RAID setup.
HD Tach 2.61 won't run with advanced test checked, and Ovi has provided the reason why, so I'll research my Archive CDR's for earlier version.
ABIT KT7A, RAID 0 * 900MHz Athlon T'bird * 256MB Crucial 7E PC/133 RAM * Two 30GB IBM 75GXP * Two Cheetah LVD's * Barracuda UW * DiamondMAX IDE * Plextor Ultraplex 40max/Plexwriter 12/4/32 * Hitachi IDE DVD * 2940U2W * SB Live * 3Com 905B-TX NIC * 3Com Courier V. Ext. * Hollywood + * Win 98SE, Win 2000 *
[This message has been edited by SCompRacer (edited 20 January 2001).]
MSI K7D Master L, Water Cooled, All SCSI
Modded XP2000's @ 1800 (12.5 x 144 FSB)
512MB regular Crucial PC2100
Matrox P
X15 36-LP Cheetahs In RAID 0 LianLiPC70
Indiana ... I have the same drive as you, IBM DDRS 39130D U2W LVD 9GB formatted with FAT32, which I just benched under Win98. I got slightly higher numbers than you using my on-board U2W SCSI (ASUS P2B-S):
