I had an idea of why the two bright spots either side of the one in the middle - they could still be releasing a new G550 with ear-casting or something.. but with good 2D quality
so by that rationale arse casting would give us 800 cos it is proportionatley larger than ears.. can someone work out the percentages for body parts? The possibilities are endless.. this is big... cool... nail casting, nostril casting, zit casting ...
What I fear most, is that the cards are to expensive.....only time will show....
cu/2 magog - Germany - flying with OS/2 Warp speed...in a vehicle named eComStation (eCS)
Author of the Java Movie Database - http://www.jmdb.de
JMDB v1.35 FINAL is available (2007-09-20)
Homepage: http://www.juergen-ulbts.de/
I think i could get more, but the 165Mhz bus with maybe 83mhz for the apg bus is about the limit with my Iwill KK266-R (only SDR Sdram) for the Matrox G400 that i have. I'm sure you guys with the newer chip set KT333, could maybe get more,with about the same or lower the APG speed and have a better bandwidth on the memory with DDR near or around 185Mhz- 200Mhz and the APG bus speed 74Mhz - 80Mhz, plus i run APG at only 2X and you could run it maybe at 4X.
But sofar I have and still hold the top scores with a Matrox type V-card, with my G400. Which is suppose to be a G400 Max, but show as only a G400, it is a replacement one that i got for my G400Max that was dieing. It benches about the same as the one that it replace, the box show Replacement/Refurbished G4+MMDHA32G. Only thing I see is it will not do APG 4X now for some reason, as the one that I 1st bought said APG 4X on the box and could run APG 4X, but it could be something i have overlooked or the newer drivers just dont offer it on install.
