I've just run some tests. I have footage recorded from a Betacam VCR with timecodes overlayed in the picture. The timecode includes frame numbers as well as field numbers, so it looks something like this: 01:23:13:08.1, where the last digit represents the field number.
Normally, when I play this footage captured in Field A mode, on the TV screen the field numbers flicker 1-2 per each frame. On the monitor, its is just 1 or 2 all the time. Is it that it shows only one field per frame on the monitor?
Anyway, I tried changing the speed (to 50%) of such clip in Field A mode or Frame-based mode (as I said, the clip originally captured in Field A mode).
What I found when I looked on the field numbers:
Frame-based mode - frames are duplicated, while both fileds per frame are preserved. So when scrubbing frame-by frame, it goes 23.1-2 23.1-2 24.1-2 24.1-2 00.1-2 00.1-2 etc. Where 23 is the frame number ,and 1-2 are flickering field numbers.
Frame A mode: EACH FIELD IS TURNED INTO A SEPARATE FRAME!!! So when scrubbing frame-by-frame it goes 23.1 23.2 24.1 24.2 etc.
So, this explains it all. The visual quality is better in frame-based mode, as you still get two original fields per frame, but you get flickering, as the frames are duplicated. In Field A mode you get fields turned frames with half the original resolution on the TV screen. Hence the deteriorated quality but less flickering.
Now, I did not try other sped settings (like 30% etc.) cause I still have some actual editing to do today.
P.S. This might deserve a separate discussion, but can you accelerate or decellerate the speed of a clip in MSPro? I mean, gradually within one clip. Like they now do in music videos or commercials, you know.
