If you're into serious effects you might want to check out the RTX100 Xtreme that is coming in June.
It's simply amazing what can be done with it and just a software upgrade to the RTX100 and for free.![Stick Out Tongue](http://murc.ws/core/images/smilies/tongue.gif)
I have been able to do 4 dv layers each with a 3d effect plus a graphic. Now this isn't RT, but with Xtreme preview you can see what you are doing all the time. With out so many effects it will play back a little bumpy on a 2000+ processor.
It's definately worth your consideration as it has RT DVD export to disk as well as mpeg1, WMV, real media that can be exported simultaneously in any kind of settings you can dream up.
As a side note I set up my RT2000 in a sis 735 and it worked fine. [ECS K7S5A] .... this board currently has the RTX in it.
Cheers....
![Big Grin](http://murc.ws/core/images/smilies/biggrin.gif)
Cheers....
