mp3: 128 bitrate vs. 192 bitrate - plz help!
    I've found that at 128kbps high frequencies tend to be messed up with a bit of "ringing" It is not so bad with lame though, but still noticeable. I supposedly have (or at least I did have in 1994) supranormal hearing tested by audiometry. VBR sounds better to me too, and usually works out to around the same size as 192kbps. Hard disks are cheap, I am considering getting a 100GB Maxtor for $228, so the increased size shouldn't be too big of a concern. However if you have your mp3s primarily for your enjoyment and can't hear a difference even when re-enciding from 192 to 128 then do so.
    [size=1]D3/\/7YCR4CK3R
    Home: M1 Mac Mini 8GB 256GB
    Frontdesk: Beelink T4 8GB
      hmmmm, well yeh, hearing is subjective, i guess if someone sais that 128 is CD quality, their right, and if another sais 192, their right too...
      <font size="1">Gigabyte GA-6VXC7-4X MoBo
      VIA Apollo Pro 133a (694x/686A) chipset (4x agp, UDMA 66)
      Celeron II 733 CPU (coppermine 128)
      128meg (2x64) 133mhz SDRam
      Matrox Milleniumm G200 AGP 16 mb
      Creative Sound Blaster Live! 5.1 Digital model 0100 (MP3+, Gamer)
      Quantum LM 30 gig HD 7200 RPM UDMA 66
      Realtek 8029A NIC Card
      Optiquest V775 17" Monitor
      Actima 36X CD-Rom
      Advansys 510 SCSI Card (ISA, but good enuf for my burner)
      Yamaha 6416 CD-RW
      Windows 2000 (primary)
      Slackware Linux 9.0(secondary/emergency)</font>
        Not at all ...
        neither 128 nor 192kbit/s are equal to CD quality, only because some people do not hear a difference.
        It's ok, if they say it won't make a difference to them, but I can hardly accept it to be put as a general statement or fact.
        Compare it to color blindness, ie. only because some people cannot differ between red and green, does that reverse the meaning of all traffic lights ?
        Intel Core i7-3930K@4.3GHz
        be quiet! Dark Rock Pro 2
        2x MSI N670GTX PE OC (SLI)
        OCZ Vertex 4 256GB
        Nanoxia Deep Silence 1
        LG BH10LS38
        LG DM2752D 27" 3D
          Maggi,
          What do you do your encoding with? I haven't looked at VBR in quite some time. The last time I did, the VBR camp was small, and crappy. Are there good encoders that do VBR now? I suppose I should look and see if LAME supports it now.
            Actually, LAME has pretty much the best VBR engine out there (but not perfect). I don't use VBR right now, but I eventually plan on re-encoding all of my songs to VBR. It seems that electronic and heavy metal music tends to cause MP3 to create more audible artifacts. Using --r3mix with LAME, I encoded some Metallica songs and each one ended up with an average bitrate of more than 220kbps.
              maggi: well this is different, if everyone was listening to my mp3's then i should encode it to 192.... also the difference is not huge to those that can actually notice it
              wombat: im using dbpoweramp, it has the LAME encoder and yes it has VBR support!
              Actima 36X CD-Rom
              Yamaha 6416 CD-RW
                I tried VBR a long time ago, but it caused a lot of artifacts and ringing. So I swore never to do that again, but in the past month or so I broke down and tried it again. Now I only do VBR with 224 high, 128 low at 3 quality. Everything sounds great to me, but I'm sure I'm not the most sensitive. Although maybe more than nehalmistry
                Gigabyte GA-K8N Ultra 9, Opteron 170 Denmark 2x2Ghz, 2 GB Corsair XMS, Gigabyte 6600, Gentoo Linux
                Motion Computing M1400 -- Tablet PC, Ubuntu Linux
                "if I said you had a beautiful body would you take your pants off and dance around a bit?" --Zapp Brannigan
