hi Patrick,
I've been looking into getting my system as quiet as possible as well the last couple of months, and I have to say that the Zalman flower cooler is a perfect HSF for that purpose!
the fan is almost inaudible in 'noise-prevention mode', and it keeps the CPU more than cool enough.
I've even tried to run without any active cooling at all, and the CPU (Cu 700E) would still run within operating specifications according to Intel! (barely though, @75 degrees Celcius). Though that was a tad too high for my liking, so I kept the fan for the airflow
I've also bought an almost completely quiet HDD, i.e. the Seagate Barracuda ATA IV series... those are completely silent during idle, and during seek they also are very hard to hear (that's with acoustic management disabled. With management enabled you can't even notice the seeks any more).
What remains is the power supply, which has 2 options:
- replace the FAN by for example a quiet Papst one
- take out the FAN and put in some major heatsinks to make the PSU passive cooled only
I'm looking into that last option, though I probably have to mod the PSU first to make it more efficient (and output less heat).
The fan in my CDWriter also is quite annoying, so I'll add some simple circuitry that makes it only go on when it's burning a cd.
