Ultra effecient new cooling device passes Boeing tests
    BTW, I was just joking about putting one of these things in my case, in the event anyone didn't get that. It's hard to tell what voltage requirements are for such a device, and besides, I'm not so sure it wouldn't be overkill. On the other hand, freezer-compartment cold inside a sealed PC case would probably greatly aid stability with extreme overclocks (imagine, ALL the components kept at or below 0 degrees C.)
    "..so much for subtlety.."
    System specs:
    Gainward Ti4600
    AMD Athlon XP2100+ (o.c. to 1845MHz)
      Thanks
      I just could not resist snaffling the Displacement Mapped spikey ball of the Matrox demo, I think I might add eyes and some feet soon
        That puppy's gonna need one helluva an active cooling setup on the hot side. It'll need active cooling on the hot side so it doesn't melt, and this may well use up a lot of what you save in cooling efficiency.
          Cool. A Matrox mascot- "Displacement Man"
          System specs:
          Gainward Ti4600
