I have a SIS651/962 Chipset in my Shuttle Mini Box and the thing is great so far! Just as nice as the SIS 745 Chipset for my AMD system. Making sure I got a SIS chipset in the minibox for me was so important that it was my first Intel CPU in years that I've gotten for personal use. The other alturntives for Minibox chipsets where Via (yuck) and Nvidia (double yuck). SIS has my motherboard busniess for the the foreseeable future!
I may have been cursed by via gods, but I´ve got issues with every Via hardware I tried/owned.
It´s not only the PCI bandwidth, it´s a lot more. There´s always some new, hidden bug that will cause some anoying problems. Just one example for the only Via hardware I use now:
My laptop has a via KX133 chipset (basically a KT133 with integrated S3 savage) and I have a annoying problem with it - I use it with my usb cable modem and most of the times (but not always) when the laptop starts up the cable modem is unusable for like 3-4 minutes. If I use the "safely remove hardware" XP gizmo, and unplug/plug again the usb cable it works right away. If I start windows and only after plug the usb modem, it always works.
Needless to say I went the long and painfull path of a typical via user: multiples 4-1 tries, usb patches/filters, cable modem drivers, usb tweaks, you name it. Never been able to solve the problem.
It always work as it shoud with my SiS 735 main system. Of course. Same OS, same modem, same drivers, same settings. Only not Via crap anywhere.
Pace, DON'T buy the VM 452 pro. I've got one. If you substract the premium you pay for NF, there's not much money left to go into quality. Of course, mine could be a bad one. I'm just in the process of having it RMA'd
What was wrong az? I love my VMPro450, and its NF (although the NF prices have dropped).
What about the HighBrightness tubes on the VM Pro 1451 17" and VMPro454 19"?
Edit: Also, what memory should I combine with the 745:
Branded PC2100 (£90), Corsair PC2100 (£140), Branded PC2700 (£100) or Corsair XMS PC2700 (175).
They are all 512MB (DDR duh) modules, and there's quite a difference between the standard and Corsair RAM (PC2700 is 75% more). Worth it? I'm guessing there's something special about this RAM, but I haven't found it yet
Edit 2: What about some Arctic Silver or similar? What'll we put between CPU and heatsink?
Don't know about the other Iiyama NF models, but they're supposedly OK. My monitor had problems from the start - "waves" running up in the lower-right corner, then it started beeping, and now it started buzzing for ~20 seconds after switching resolutions. As I said, this might be due to a bad model. But worse yet, it isn't sharp at 1280x960@85 (It's really not usable, because you can't read this site at that resolution anymore without getting very close to the monitor, and getting eyestrain), 1024x768@85 works almost fine though. White icons on a black background kind of "shine" - like you have fat on your glasses and look at a light.
I have not yet had it RMA'd because the shop I got it from forgot to have me pay
Iiyama support will pick it up in a few days though and repair it (or give me a new one), and I'll get a replacement 19" monitor for the time. If you have a little more time before buying (~2 weeks) I can give you my experiences with Iiyama support (has been very nice and fast so far), and if the repaired monitor is any better. Maybe the replacement they give me will be a 452 too, so I can definately tell you if the sharpness issue is because of a bad model.
I can't believe my Hercules 3D Prophet 4500 (Kyro II chipset) has that worse image quality at 1280x960x32@85Hz, so I blame it on the monitor. I've only had a Matrox Millennium before, which is not at my home anymore, so I have no means to check whether it's the monitor or the card.
