Upgrade from G400 to 9700Pro
    Found another problem. Not sure if this is due to the Radeon or my monitor (Dell 2000fp).
    If I have the monitor connected via the analogue connection, when I turn the computer off, the monitor goes into standby like you would expect.
    If I have it connected via DVI then when I turn the computer off, the monitor displays a message saying "no signal, check your connection", and it floats around the screen. I left it for about 10 minutes to see if it would go away, but it didnt. I had to turn the monitor off.
    Anybody have any ideas?
    Ali
