Some Questions About SCSI
    If you run WinXP, the SCSI drives will not perform on par.
      Buddman:
      There are few things that really *need* scsi (video-editing come to mind). I can only say that in my case, it made the system far more responsive, but you must know that I went from an old (slow) IDE-drive to a 10K SCSI. What also plays a part is that my current system still is a PII-450, and the IDE on that board requried more CPU-usage than SCSI (this is no longer the case, IDE has improved a lot). The difference between my drives and recent IDE-drives performance wise would be far less than what I have experienced.
      The only other reason I can see for going SCSI, is the added extendibility: in my sytem, I'd have to few IDE-ports if my system was using IDE exlusively (2 HDD, 1 DVD (the only IDE device), 1 CDRW, 1 SCSI ZIP250, and another harddisk on the way), and all PCI-slots are filled up.
      Umfriend has made a great suggestion...
        Well, I will actually be using the comp for video editing for my job at Fox News. That's why I went with the AIW 9700. If I go for a 15k rpm drive, then I'll have to limit the CPU to a 2.66. If I get a 10k rpm drive, I can get a 2.8.
        EDIT: Though I will be using the comp for video editing, I should add that I won't be doing very much video editing on it. Just only when I need it to save me a trip of going into Austin.
        System Specs:
        Gigabyte 8INXP - Pentium 4 2.8@3.4 - 1GB Corsair 3200 XMS - Enermax 550W PSU - 2 80GB WDs 8MB cache in RAID 0 array - 36GB Seagate 15.3K SCSI boot drive - ATI AIW 9700 - M-Audio Revolution - 16x Pioneer DVD slot load - Lite-On 48x24x48x CD-RW - Logitech MX700 - Koolance PC2-601BW case - Cambridge MegaWorks 550s - Mitsubishi 2070SB 22" CRT
        Our Father, who 0wnz heaven, j00 r0ck!
        May all 0ur base someday be belong to you!
        Give us this day our warez, mp3z, and pr0n through a phat pipe.
        And cut us some slack when we act like n00b lamerz,
        just as we teach n00bz when they act lame on us.
        For j00 0wn r00t on all our b0x3s 4ever and ever, 4m3n.
          Isochar: Why is that ? (I'm currently running W2K, in which there is a difference)
            Hmm, I just found another reason to go SCSI: drive warranties ! On a lot of SCSI-drives, they offer warranties up to 5 years, in comparison to the 3 years (or sometimes even just 1 year) with IDE drives:
              BuddMan, if you plan on keeping the processor for a while, I'd tell you to go with the new 3.06 P4s so that you enjoy the benefits of SMP/SMT.
              VJ, this is a long discussed bug in WinXP. Microsoft has been working on a fix for the past couple of months, but no sign of it yet. Look at this thread:
              *edit* To give you an idea of how bad this "bug" is - there are situations where reviewers have found 5400rpm IDE drives beating the new Cheetah 15k.3 in read speeds. :/
                Thanks, I'll read up on that thread (guess I'll postpone the move from W2K to XP a bit longer...).
                  Well... I _really_ think you're underestimating the amount of noise that a fast SCSI drive makes. I mean, we're talking "low flying aeroplane" noise levels here. Seriously.
                  - Gurm
                  I'm the least you could do
                  I would still get screwed
                    Well, I admit, it makes a lot of noise, esp. during seeks. The Quantum is a lot noisier than the IBM wrt. spinning noise (whining) and short stroke seeks.
                    I can imagine that some people would mind, I personally don't... although I won't use my computer to watch dvd movies, and I prefer it switched of when I watch TV (a few metres away). The sound is "muffled" somewhat by the 4x80 mm fans that are cooling the case. I do intend to put some noiseblocker mats on the inside of the case, just to isolate it more.
                      Dunno about you, but I think that buying a good SLR camera and a film scanner is a good way to spend your money.
                        An alternative is to go digital SLR : I'm using a Nikon D100, and it is just great fun to use. But I think you'll need more money than a SCSI-setup...
                          On the XP/SCSI-issue...
                          Is this the definite solution ?
                          Or is the SCSI-performance still not at maximum ?
                            Given the current speed of IDE, I think the only reason to go scsi is expandability/flexibility.
                              VJ: It's still not up to par.
                              MS has supposedly "fixed" the problem in SP1... but people are saying it still isn't all that.
                              And this goes for IDE-RAID as well, since that enumerates as a SCSI device.
                              I hear it's MUCH better with SP1, but still not as good as in XP.
                              And heed Dogbert's advice - the noise coming off a 10k drive is just obscene.
                              - Gurm
                                Gurm:
                                Ok, thanks for confirming... There are some threads over on 2cpu on the subject, and they also confirm it is not up to par (70%-90% performance)...
                                Is there any known cause (certain chipset, controller, ...?) ? Or does it just always occur ?
                                (I should think there are XP-servers with SCSI-disks out there)
