Those capacitors are easy to unsolder (and replace by new ones) with a standard soldering iron (30 watts) if you have a fine enough tip. Did that myself with a noname VIA-based P3-mobo.
As for buying some new caps, either order them from www.conrad.de or www.reichelt.de or you could ask a local radio & TV technician.
I am a bit clumsy with the soldering iron but i know a guy who does this for a living so that is sorted out as well
