When comparing formats one must take other aspects into consideration as well. If the mixer of the SACD takes the CD master and just slaps it on the new format, there won't much, if any, difference.
If however the SACD is taken from a high res master or specifically recording for the high res spec (i.e. DSD for SACD) and specifically mastered for a new format, SACD or DVD-A, then differences can be heard on a system capable of producing the needed sound.
If you play it back on a $250 Best Buy special all in one box home theater package, you probably won't notice the difference. A nice HiFi package would make a difference.
And yes I have listened to CD, HDCD, SACD and DVD-A on various systems and there is an audible difference.
The difference between CD and HDCD is more nuance and a bit more depth to the music. The difference between a good CD and a good SACD/DVD-A is more accurate, full sound, plus the afore menttioned nuance and depth.
And if you don't beleive me, so be it, I don't care. It's not my fualt you can't hear well.
Jammrock
Jammrock
(in my case, sony casette (yup, analog!
