Glad it worked.
(must be karma from the BIOS flashing idea
I tend to disagree with Chucky Cheese on drive placement. The whole point of the terminator is to prevent reflections. If it's working correctly, there are NO reflections on the cable (it looks infinitely long ti an impulse). Of course, the terminator has to be at the end, but once that's done, you can put drives anywhere.
The only thing that could be useful is if the drive powering the terminator (assuming active termination, which I think is required for U160 and U320) is too far away to supply clean power to the terminator. (That seems unlikely, but it's possible (maybe))
Chucky: Can you point me to something on the web suggesting that the drives are placed close to the terminator?
Thanks
- Steve
edit: typo and word rearrangement for clarity
)I tend to disagree with Chucky Cheese on drive placement. The whole point of the terminator is to prevent reflections. If it's working correctly, there are NO reflections on the cable (it looks infinitely long ti an impulse). Of course, the terminator has to be at the end, but once that's done, you can put drives anywhere.
Thanks
- Steve
, but the manual is the same for both a standalone controller as an onboard one...).
, we found out later that some VIA chipsets indeed do this)
