Originally posted by Fluff
Peoples thoughts on DRM
Originally posted by FluffWombat, the issue with things like damaged media, is a problem. Maybe with items such as DVD-audio discs / SACD they might not have as much of an issue replacing the damaged media. I don't know.
With vinyl get a scratch or a jump and you are screwed anyway. No one will replace it unless it's a manufacturing defect.Gigabyte P35-DS3L with a Q6600, 2GB Kingston HyperX (after *3* bad pairs of Crucial Ballistix 1066), Galaxy 8800GT 512MB, SB X-Fi, some drives, and a Dell 2005fpw. Running WinXP.
Originally posted by WombatYou know. I know. They'll still refuse to replace it.
So why is it illegal for me to copy a friend's record? Or a copy of my own record, and use the copy instead?
Hmm, that's a hard one.
From that cassette law that allows you to tape a cd. That is equivalent to making an mp3 from the cd and giving that to your friend. As it is not a 1:1 copy. There is a loss of information. That should be ok.
I think if you copy a cd to cd-r, then copy that cd-r, repeat 10 times. You should be able to notice a loss of quality. Therefore it is not a perfect 1:1 copy, there will be jitter errors, due to the format standard. Even if it is 'digital'. That should be allowed too, and included under the cassette law.
If record companies were to release master quality material i.e. 24bit/96khz or equivalent. I believe that should be heavily protected as it is with SACD / DVD-A. DRM or equivalent.
Havent really answered the question though.______________________________
Originally posted by WombatDRM is universally bad. The problem is that DRM cannot distinguish intent. The techological path to make a backup of something so that your toddlers don't destroy the original is the same path that one would use to make illegal copies for the rest of the world. You can't block one without the other. Don't impede my fair use.
I think if you copy a cd to cd-r, then copy that cd-r, repeat 10 times. You should be able to notice a loss of quality. Therefore it is not a perfect 1:1 copy, there will be jitter errors, due to the format standard. Even if it is 'digital'. That should be allowed too, and included under the cassette law.Gigabyte P35-DS3L with a Q6600, 2GB Kingston HyperX (after *3* bad pairs of Crucial Ballistix 1066), Galaxy 8800GT 512MB, SB X-Fi, some drives, and a Dell 2005fpw. Running WinXP.
I read some good article on DRM. Problem with any encription or key scheme is that normally encryption works like this:
A gives some info to B and encodes it with key C. Provided B has key C, B can decode information. D doesn't have the key and thus cannot decode information.
With DRM it's different.
Some content maker wants to sell you content but wants you to prevent decrypting it. But in order for them to sell you content, you need to be able to view content, thus they also need to supply you with key. So as long as you can acess content you can copy it or reverse engineer the key and thus encryption schemes don't work.
Wombat,
Please note that there is currently NO valid CD-audio protection scheme that actually works, and any CD's protected in this manner are deemed "defective" and subject to immediate refund.But you can rip them anyway, no problems. Just hold down "shift" when you put them in the drive.
Also please note that DVD-Audio has been cracked.The Internet - where men are men, women are men, and teenage girls are FBI agents!
I'm the least you could do
I would still get screwed
Originally posted by GurmPlease note that there is currently NO valid CD-audio protection scheme that actually works,
Originally posted by WombatYes, I'm aware of this. And though they're easy to defeat, the fact that it's illegal to do so is absurd.If you find one that's copy-protected, you are under no obligation to continue owning it, and won't get in any trouble for bypassing the copy protection on it.
Or a sharpie or whatever. What happens later, when they're illegal AND difficult to crack?The Internet - where men are men, women are men, and teenage girls are FBI agents!
