The very latest supermicro nforce 4 dual opteron dual pci-ex 16 board, still has PCI standard ISA bridge in the device manager, I think its used for sensors and things like that, it does not actually have an ISA slot though
PCI to stay for a long time it seems...
Originally posted by Dr MordridThe PCI-PCIe bridge on my system works well with the TBSC falls on its arse with the RT.X100, which really hammers PCI to host memory bandwidth. Too bad, but then it's for SD editing and HD is the current thing
In short: PCI-X (eXtended) is an extension of PCI , it's backwards compatible with PCI and you find it mostly in servers and workstations. It's like the normal PCI bus a parallel bus and unidirectional.
PCIe or PCI Express is a new bus it replaces PCI and AGP. PCIe isn't backwards compatible with existing PCI cards. It's a serial bus and allows bidirectional communication.Main: Dual Xeon LV2.4Ghz@3.1Ghz | 3X21" | NVidia 6800 | 2Gb DDR | SCSI
