Originally posted by tjalfe
10Gb Ethernet being standardized.
Well, in telephony (nortel) systems, they use fiber optics for all kinds of short distance stuff (cables rarely go past 3m). Those cables aren't that expensive. Speaking of audio systems, an SPDIF cable costs less than hi-grade mumbo-jumbo 'pure copper' yada yada cables. And no, I don't care about the horrendous 'jitter monster'. Point is, a single optic fibre leads 8 channel DTS sound from a DVD to a HT receiver. I don't know exactly how many KB that makes per second, but AFAIK that's quite a lot and rather cheap."For every action, there is an equal and opposite criticism."
Originally posted by TransformXWell, in telephony (nortel) systems, they use fiber optics for all kinds of short distance stuff (cables rarely go past 3m). Those cables aren't that expensive. I don't know enough about those.
Originally posted by TransformXPoint is, a single optic fibre leads 8 channel DTS sound from a DVD to a HT receiver. I don't know exactly how many KB that makes per second, but AFAIK that's quite a lot and rather cheap.Gigabyte P35-DS3L with a Q6600, 2GB Kingston HyperX (after *3* bad pairs of Crucial Ballistix 1066), Galaxy 8800GT 512MB, SB X-Fi, some drives, and a Dell 2005fpw. Running WinXP.
Originally posted by Jon P. InghramThat's 11.6 gigabytes/sec, more than the HyperTransport bus on AMD processors can handle currently. Nobody needs that much bandwidth, it's just plain obscene!
On the other hand, if you have a server farm with a few hundred servers, serving a few million clients, you may want this kind of bandwidth on the backbone. There is no such thing as "too much bandwidth". There will always be a way to fill it up.Lady, people aren't chocolates. Do you know what they are mostly? Bastards. Bastard coated bastards with bastard filling. But I don't find them half as annoying as I find naive, bubble-headed optimists who walk around vomiting sunshine. -- Dr. Perry Cox
wet welds, sorry I forget the technical name.
we used to use them for temp splices if a single mode trunk cable was cut.
for around the office, short runs of less then a few hundred meters multi mode is fine, they can also get away with visible light lasers.
As for using fiber in nortel equipment even for short runs, its simple, a pigtail is about 3mm in diameter, cat6 is closer to 8mm. when your talking a few hundred links, I'll take the pig tails thanks.
splicing fiber is not that hard, as said above, wet welds are fine, as long as the db drop is no more then 3db it is not an issue for the sort of networks were talking about here. hell I have multimode fiber running into my house.
The real problem is lack of commercial/consumer demand.Juu nin to iro
