Networking
    Hele - I'm not sure, but are you saying that you cannot get a 10/100 hub? I have a 5 port hub which each port is a 10/100 one and I have 3 100mb cards, and a 10mb one plugged into it and they all work together a treat. It was not particulaly expensive either.
    It's a 100mb NIC which has 4 ports on the back of it. It cost me around £50.
    Cheers,
    Steve
    Yeah, you know the score...
    (ICQ: 29468849)
      Steve,
      Actually, you are correct. I just realized that my own company sells a 10/100 hub and they do it by having 2 seperate backplanes, one for the 10Mb and one for the 100Mb. I'm not sure how they talk to eachother though. The bottom line is that the 10/100Mb hubs are not very common. Thanks for pointing that out Steve
      Dave
        alright I guess it is too much work and money to get old to mix with new. I just wanted to know because my friend with the crap network plays more games I like than the other with the fast network.
        Thanks for all the info,
        Thien
          Well actually, now that 1000BASE-TX has been ratified you should go with that.. hehheh
          Maybe not yet.
          B
            Burri,
            Yes it would be nice if everyone had Gigabit Unfortunately it only works with fiber now and is way to expensive. They are creating a standard though for Gigabit over copper.
            Dave
              1000BASE-TX has already been ratified, Dave.
              (T=twisted pair, F would be fiber)
              B
              [This message has been edited by Buuri (edited 07-20-99).]
                Im not sure if they already answered this.
                A few old hubs have coax outpput, 2 rj-45's into that and hook in the coax.
                1 more option, you can always buy rj-45 to coax converters!
                What the hell are we doing in the middle of the desert?
                  Zyn, If you mean transceivers, they are far to expensive to bother with, and if you're talk baluns, they won't work as the voltages are different between UTP and Co-ax.
                  Colin
                  You wanna piece of me? here, *crunch*, o.k. not _that_ bit.
