The G400MAX came with PD5.25. I've downloaded the latest version of Uninstaller and used it every time I've changed drivers. I'm also aware of the patch required to run Rogue Squadron with Matrox cards and I have that installed.
I have noticed something unusual though. The Uninstaller does not remove all of the files it claims. If I run it, reboot and try and install an older version of PD (like I have done earlier today, going from 5.41 back to 5.30) the installer reports that one of the files is older than one that already exists on the system.
I've also noticed that whichever version of PD I install (using it's Setup.exe), after rebooting Windows prompts again for a driver for the card.
Could the problem lie somewhere other than with the G400 drivers? Could there be a basic incompatibilty with the Tyan mobo?
And... Uninstall doesn't unpack any Readme file. Just the Uninstal.exe, Setup16.dll and Setup32.dll
Thanks
Rob
[This message has been edited by Rob G (edited 11 January 2000).]
Thanks
Rob
I just don't want to waste any more of my time with it.
