AMC: that sounds like you're using the screensaver-version. Set it to "run always", and "blank after 0 minutes". A better solution would be to use the i386-winnt-cmdline.exe version. Get it from http://setiathome.ssl.berkeley.edu/unix.html .
Way to go Maggi! Fire up those fridges again
In the lower ranks (but rapidly rising), Xenosynth isn't doing too bad either...
Martin
Martin
