Brian,
Do you have a green 10/BaseT light on your modem?
Do you have a green link light on WAN side of your router?
Do you have a green link light on the LAN side of your router?
Do you have a green link light on your NIC?
Did you go to the DHCP tab on the Router setup and enable DHCP?
These are the first things to look at.
chuck
PS. I think you will have to uninstall your PPPoE software.
chuck
