Here's a link for an explanation of the differences between switches and hubs:
http://nospin.com/2000_01/2000_16.html
Kookstick - Get a DSL router if you change hardware. They do the same job as a switch, and in addition provide a DHCP server function (assign IP addresses) and also provide a hardware firewall. The better ones also allow you to open and close ports according to your needs (Zyxel). This gives you flexibility in your use of them as firewalls for games servers and other things. Again, I'm a little out of my depth with networking, but these routers are the tools meant for the job you have.
If you go with a switch, you will have to set up a firewall independently for both computers.
[This message has been edited by Brian R. (edited 04 October 2000).]
So something must be either configured wrong or defective. Might be time to call the ISP and get additional info too.
