a good old way to make good use of ur large memory is to increase the disk cache, file and directory cache.
In win9x u should goto to system applet, performance, file system, typical role of this computer and set it to network server.
This will increase the directory and file name cache.
for the disk cache, edit ur system.ini file and add the section
[vcache]
MinFileCache=24576
MaxFileCache=49152
this is for a system with 192 MB ram
the min is set as 1/8 of main memory and the max is 1/4. in KB (and make sure u multiply or divide by 1024) as 16 MB is 16384 KB, 32 MB is 32768 KB
I think for large memory (192 or higher) u can just set min=max=1/4 main memory.
or u can grab cacheman or X-setup and they'll do the job for u.
just my 2 ps. on how to fill over ur ram
If anyone knows about similar settings for NT/2000 .. just speak up.
[This message has been edited by arbymo (edited 13 November 2000).]
[vcache]
MinFileCache=24576
MaxFileCache=49152
