How to get Dolby Digital sound on PC?
    I'll wait until 3dss has reviewed it. They tend to have more technical knowledge.
    [size=1]D3/\/7YCR4CK3R
    Home: M1 Mac Mini 8GB 256GB
    Frontdesk: Beelink T4 8GB
      HARDWARE: Acoustic Edge 5.1-Channel Surround Sound Card
      11/07/2000
      Retail: $99.00
      Company: Philips
      Reviewed by Marc Rigney
      "The card itself uses a slightly different way to attach speakers, using a cable with a mini-DIN attachment on one end, and with three female stereo connectors coming out of the other. The three cables are labeled for Front L/R, Rear L/R, and Center/Sub. This will allow you to hook up almost any set of PC speakers on the market, making this the most flexible sound card we’ve ever seen. Compare this to the Creative SoundBlaster Live! Platinum 5.1 we reviewed a while back. That card had a proprietary out that only allowed you to attach those horrible Cambridge Soundworks DTT3500 speakers to get 5.1 sound."
      That is a lie, the Live! allows the same Front L/R, rear L/R and C/S connections.
      Read other reviews, if they tell a blatant lie like that I can't trust anything else they have to say
        Denty...I think he was refering to digital connections to get Dolby Digital. If I read the review correctly, I think he meant that a the S/PDIF output on the Philips AE card would put out a 96kHz/24 Bit stream for ALL sound.
        The Digital DIN connection is a great idea, but limited seeing that most of the crowd here that are audiophiles of varying degrees seem to have a bent toward home theatre gear instead of desktop speakers.
          Update:
          Yes, he was referring to Digital connections to an external decoder.
          My (Current) Primary system:
          Abit BE6 (QP BIOS)
          P3 450
          384MB PC-100 SDRAM (Non-ECC)
          Matrox Marvel G200-TV AGP (NTSC) 16Mb w/ HW-DVD Module v2.7 BIOS
          Quantum 3D Obsidian X-24 Voodoo2 card PCI66
          Linksys LNE 10/100TX PCI NIC
          SBlive (W/ OD I/O Card, Liveware 3.0 + Update) PCI
          ADS Cadet Radio Data AM/FM Card (8 Bit ISA)
          3x WD AC28400 EIDE HDDs (ATA66 Enabled)
          Creative DVD5241E EIDE 5x DVD-ROM
          WinME(English)
          DirectX 8
          My (Current) Secondary system
          Data General-ALR2650(v.005 BIOS)
          2x P2 266 (SMP)
          128 MB PC-100 SDRAM (ECC)
          2 x Number Nine Revolution 3D 8MB PCI Adapters
          Adaptec 62011 10/100 PCI NIC
          Onboard Adaptec AIC7890 Onboard Intel 82558 PCI NIC
          Onboard Cirrus Logic SVGA PCI adapter (Disabled)
          Adaptec 2930U SCSI adapter PCI
          Creative ModemBlaster 5630 Data/Voice/Fax Modem (PCI)
          Creative Labs SBLive Live! (Full Version)
          2x WD 4.5 GB Enterprise SCSI3 HDD
          Panasonic LK-MW602 CD-R
          Nakamichi MBR 7.4
          Windows 2000 Pro /w SP-1
          DirectX 7a
          Tertiary system:
          P233MMX
          Asus TX-97XE
          128MB RAM
          Creative Savage4 32MB PCI
          2x Creative Voodoo2 2MB (SLI)
          Intel Create&Share Video Capture PCI
          Creative Labs AWE 64 Gold
          Intel PRO100 10/100 ISA NIC
          ADS Cadet AM/FM RDS receiver card (8 bit ISA)
          Linux Mandrake 7.1/ Win98SE
          Quaternary system:
          P233MMX
          64MB RAM
          Asus TX-97X
          Number Nine Imagine 128 4MB PCI
          Linksys LNE-100 10/100 PCI NIC
          Onboard Creative Labs SB Vibra16
          Pentenary System:
          Dell Inspiron 7100 Laptop
          Xircom 56k-10/100 PCMCIA NIC/Modem
          Lots and LOTS of CAT5 cable in my walls.
          Even more spare parts...
          one very angry wife.
            There's been an interesting thread going on in the AVS forums about the quality of digital data streams coming out of HTPC rigs. A Dolby Labs employee (handle is thager) just got done conducting some tests and concluded:
            ... These results provide strong evidence that the ones and zeros representing AC-3 (and probably DTS, to be fair) coming across the S/PDIF port from your HTPC are exactly the same whichever sound card or DVD player you may be using.
            Good info in this thread. Go check it out.
              Wow, it's always nice to get a professional opinion.
