CDDB's are not equal. The CDDB used for AudioGrabber is practically flawless. If they think there is more than one possible match it will give you a list and let you pick the correct one.
PlayCenter and WinAmp may have used the same/similar CODEC, but Playcenter 2 doesn't. The CODEC they use is really crisp and gives the music nice tone. I've really enjoyed it so far. The only problem is that it's bulky and slow like WMP7.
Jammrock
Jammrock
