Re: Question 3---
You don't need to wipe your entire hard drive when you install a new mobo (no matter what mobo you choose), but you <font size=4><u>absolutely</font> must</u> remove all the system devices from the Device Manager <u>in Safe Mode</u> (preferably right before shutting down and removing/replacing the old mobo).
If you don't do so, you will get about a million errors as Windows tries to read your new devices (such as the IDE controllers, the PCI bridge, and the hateful Power Management Controller), and cannot reconcile them with what it has in the Registry.
No need to disturb your installed programs or anything like that, but do yourself a favor and delete all those motherboard-based devices before you do the upgrade-- unless you're a big fan of Safe Mode (which is all you'll likely be able to boot into until you do).
Holly
[This message has been edited by HollyBerri (edited 04 February 2001).]
Holly
Needs better memory to push it any further but he's happy enough.
