Wombat, you should definitely ask this question to Creative! I have no idea what kind of drugs their development team is taking to get noise on a digital out - but there is. Just test it yourself with a digital reciever.
This is one of the good things about the Onkyo - nearly no noise even when the volume is turned up fully, and none hearable without headphones if the digital inputs are used.
BUT with the Creative Undead! SP/DIF connected to the reciever there actually is quite a lot of static plus extra noise when you move the mouse, scroll text, HD-activity is taking place (and this noise can be actually heard at normal volume-levels). Just like you'd expect from a bad analog-out - just that Creative manages this in digital, some kind of "digital-quality static/hum (tm)"...
LiquidSnake, to my knowledge LAME and Fraunhofer codecs do process the full frequency range when the HQ-switch is checked. But then I normally don't use bitrates as low as 128Kbps.
[This message has been edited by Indiana (edited 17 June 2001).]
But then maybe the newer Fraunhofer-encoders are better quality-wise than the old one I've abandoned for lame.
