HL2 Problems
    where do you get the cleaner?
    -We stop learning when We die, and some
    people just don't know They're dead yet!
    Member of the COC!
    Minister of Confused Knightly Defence (MCKD)
    Food for thought...
    - Remember when naps were a bad thing?
    - Remember 3 is the magic number....
      I don't have this problem on my Parhelia :0
      Works great by the way, but I believe DX9.0 is running in software.
        try googling for driver cleaner.
        Well I finished the game and I think my gfx problems are with the card itself...it starts to mess up after a couple hours of straight use. I checked my Clocks using ATITool and its at its stock clocks
          They have a DX8 code path for the engine
            Thanks...
            Member of the COC!
            Food for thought...
              ATI themselves have their own driver cleaner on their website, just look in the extra tools/utilities section
                so for the sake of it, why not underclock it and see if the problem persists ?
                Seriously, "stock speeds" are no guarantee that it won't overheat with an application that is more taxing to your system than the ones they used for stability testing, back when they settled the clock speeds.
                Also, if the problem disappears below stock speeds, you might have a reason to excahnge the card.
                Intel Core i7-3930K@4.3GHz
                be quiet! Dark Rock Pro 2
                2x MSI N670GTX PE OC (SLI)
                OCZ Vertex 4 256GB
                Nanoxia Deep Silence 1
                LG BH10LS38
                LG DM2752D 27" 3D
                  Been hearing a few people say turning off fast writes helps.
