g400max , PIII and q3test2 (1.06)
    Oooopssss....
    my mistake.....
    Well I played a little around with the settings, and if I leave the Texture Size on High, disable High quality sky and texture mode: GL linear MIPMAP Nearest
    Texture Quality: 32 Bit
    Color Depth : 32 Bit
    resolution: 1024 * 768
    and Billinear filtering
    I get: 34 FPS with my G400 - 16 MB..... :-)
    in the timedemo1
    It's playable, and looks nice 2.....
    But still, when I use Texture Size Highest
    the performance drops like an fly..... :-(
    But only after a second or 15 - 20....
    The first 15 - 20 seconds the timedemo1 runs
    good. After that is hopeless.......
    What's goin' on here??????
    Drivers????
    MarcelM
    G400-16MB, Abit BX6 rev2, 96 MB, 6.4 GB Hdd (3x), Pent. II 350 Mhz (3.5 * 112)
    Abit BX6 Rev 2.0, 96 MB, Matrox G400 32 MB DH, Intel PIII ~ 527Mhz, SBLive! - LiveWare 3.0,
    3 x 6.4 Gb Hdd's, Adaptec 2940UA SCSIcard
      The texture size gets really BIG when set to the highest setting !!
      So i think the 16 MB RAM is not enough and not the g400 !
      Besides : Someone mailed me that he got 46 FPS on a herc tnt2ultra !
      I boosted my creative tnt2ultra to 170/210
      and got ~40 FPS at 1024*768*32 all details maxed out EXCEPT SKY OFF AND ONLY BILINEAR !
      I hope to break the 50 FPS barrier with a g400max and my PIII558 ;-)
      Now i play at 16 BIT at 55 FPS and when i can get this at 32 bit i will change ;-)
      Cu..........
      p.s.: FOR ALL THE OTHERS : GIVE ME NUMBERS !!!!! (quake3test2 32 Bit 1024*768*32 all settings at the max , only sky off and bilinear !!)
        "PLEASE COULD SOMEONE POST BENCHMARKS !!
        I am interested in 1024*768*32 , 32 bit textures , AND ALL SETTINGS TO THE MAX ( EXCEPT ONLY BILINEAR AND ONLY SKY HIGH SPEED) on the map q3testdemo1.dm3 !!"
        Sure thing.
        "DUAL TESTS are welcome too !"
        Okie Doke
        "My System : PIII 558 (oc) , tnt2ultra (170/190) , 320 MB ram -----> 36,6 FPS !!"
        My system: dual celeron 512 MHz, tnt2 ultra 150/183, 128 MB ram -------> 35 FPS!!
        Just so you know. SMP makes almost no difference.
        "You should have a PIII and a g400max !"
        Sorry man. I cancelled my G400 MAX when it became apparent the wait was going to be ridiculous.
        "DonĀ“t forget : ONLY SKY HIGH SPEED and BILINEAR all else FULL DETAIL , EVEN SOUND !"
        Did just that.
        What can you get from these results?
        TNT2 Ultra is the holdup.
        Scotty! We need more power!!!
          TnT2 is the holdup ?
          YES and that is why i will get a g400max .
          I am sure it will be by the end of july or the beginning of august !
          I overclocked my tnt2u even further (170/215) and it is clear that the fps is rising LINEAR with the mem clock !!
          Now it is 42 FPS !! (instead of 37 !)
          Cu........
            Hi Joel,
            I use g200clk /1 300
            I get much better framerates then when I would use g4set.
            I did like u wrote:
            g4set -sclk 300 -div 1/2 2/3 1/2
            Now I get only 16.02 FPS in Q3testdemo 1
            at 800 * 600 * 32
            When I use g200clk /1 300
            I get 35.7 FPS using 800 * 600 * 32
            Marcel
              I just got done downloading Q3atest2.
              Me and my G400Max will do a little benchmarking tommarrow and I will post it.
              Patience is a virtue. I guess you never heard of that.
              What the hell are we doing in the middle of the desert?
                Patience is a virtue is a nice saying, but Fools rush in, is another.
                Please do post your results on you card.
