I have two more computers I can add to my arsenal but I am running into a problem. They won't connect to Seti. According to the Seti FAQ, it uses port 80(http) to send and receive data. This is good because port 80 is so widely used that it shouldn't be a problem. I know that I sit behind 2 firewalls. I have seen the config of firewall A. There is nothing to the config and I can browse the web with the same computer tht I am trying to use Seti on which means that I should also be able to use Seti. I do not have access to firewall B but since I can use a web browser on port 80, I would assume that seti would work as well, but NO GO
Anyone has any ideas?
Thanks,
Dave
![](http://forums.murc.ws/ubb/frown.gif)
Thanks,
Dave
