Now its screwed up again ... grrr ...
problems with Opera ?
Might still have nothing to do with it, but the past hour I was online static on the main page here (Watching the Weakest Link). When I came back I refreshed the page 3 times, but my name wasn't in the list of people on the forums. I am no longer in invisible mode. After refreshing my cookie (logging out, logging back in) my name returned.
Pages still don't load completely here, but at least my loading bar gets stuck at around 98%. Bit of a bugger when you want to scroll using the cursors, but otherwise the pages have completely loaded (all pics etc. are visible)
Using Mozilla 0.9.5+ (07112001) here.
Jord.
Edit at a later time: I have found that I will be lost from the list after about 5 minutes. I just did my 7th logout/login of the day. And I'm gone already.
Then after a post like this I am back. For 5 minutes
I'll talk to the vB guys about it, can anyone narrow it down to exactly when it started?), but my guess is less then a month and a half ago...
I went to the vB site, and tried to access some other forums, none seem to give the problems I experience with Matroxusers... (the forum, that is)
Ant any progress?
I'm having the same problem as Jorg at the moment: page loads up to 95%, and reloads (and gets stuck in this loop)...Main: Dual Xeon LV2.4Ghz@3.1Ghz | 3X21" | NVidia 6800 | 2Gb DDR | SCSI
