Out, Out Damned Dust!
  • Marshmallowman
    • 3416
    plants will purify air.
    whareas - ion mainly drops dust and pollen out of the air.
    saw one in action, after an hour there was large amount of dust/stuff collected on some sheets of paper we put on the floor in front of it, a real eye opener.
    I don't have any hayfever/allergies but I have been looking to get one for a while.
    if you want to try out a safe cheap one, look here
    if you keep one running and, regularly vacuum around it it caould do a reasonable job in a small room.
    heres a car one
    just modify the power connector, and plug it into your PC
    I will do a bit more searching and see what I can come up with.
    • TiG
      • Jan 2001
      • 111
      Good job Marshie. Nice to see someone was working while I was off playing green thumb
      "You win again gravity!"
      • Greebe
        • 8555
        Have any of you priced a commercial electronic air filtration systems before?
        Those are damned expensive compared to these.
        Negative ION generators work by charging the particles which then attach themselves to a positively charged surface... which means they coat the immediate area.
        BTW the Quadra is only $175... I'd be looking for something similar
        Small price to pay when your alergies are as extreme as they are.
        • Dogbert
          Better use Anti Histamin
          • TiG
            • Jan 2001
            • 111
            ION's don't really sound like what I need then. Unless it has hospital grade filtration, a Vacuum Cleaner is just a powerful particle re-distributor. I avoid them completely.
            Your right Greebe, it would be money well spent if it's effective as they say. Better do my homework and find the right one.
            I've just started on long term Anti-Hists this week Dogbert. So far I'm feeling better, although a tad sleepy.
            Big thanks to everyone for their legwork. I'm already breathing easier!
            • Marshmallowman
              • 3416
              yeah, go with a good filter system as greebe suggests...-ions work but you really need a good filter combination.
              Looking around I get the impression that a lot of these sites are just snake oil merchants.
              this site has some reasonably looking filtered units, and they are in Australia
              • Rags
                • 4052
                ozone generators work good too, but like Mike said, ozone is a toxic substance and care has to be taken.
                Many swear by having the ozone going while at work and turned off while at home. This combined with a HEPA filtration can work wonders.
                Rags
                • Technoid
                  • 7645
                  My vacuum cleaner has dual HEPA filters
                  • TiG
                    • Jan 2001
                    • 111
                    Is it a Dyson? They seem quite good
                    • Technoid
                      • 7645
                      Actualy I don't remember the brand...
                      I got it as a birthday gift when I moved into my new apartment.
                      Will check when Iget home
                      • xortam
                        • 4534
                        #26
                        I love the smell of ozone in the morning: It smells like ... electricity.
                        We used to have a commercial grade negative ion generator in our office back in the early '80s (when you could still smoke inside buildings). The room housed eight engineers who all smoked and the generator prevented the smoke from bothering the neighboring rooms: It really worked.
                        • Duty
                          • Apr 2000
                          • 714
                          #27
                          I know the feeling; I generally can't take the stuff if I want to stay awake. Talk to your Doc, they have stuff out now that is really good about not causing drowsiness. It took me a few years to find the stuff that works for me (its called CTM).
                          Good luck,
                          Jeff
                          -We stop learning when We die, and some
                          people just don't know They're dead yet!
                          Member of the COC!
                          Minister of Confused Knightly Defence (MCKD)
                          Food for thought...
                          - Remember when naps were a bad thing?
                          - Remember 3 is the magic number....
                          • TiG
                            • Jan 2001
                            • 111
                            #28
                            Since this is only the 5th day of taking them I'll wait and see if it gets better. If not, I'll have to try a different med. Appears to be just trail and error.
                            • Greebe
                              • 8555
                              #29
                              Actually vacuum cleaners with HEPA filtration work very well at removing the dust you are weary of.
                              Heck you can actually use a Fram auto air filter (or other similar type/brand) and a cheap fan to make a decient HEPA air filter for your room... oh say for like $20-30
                              • TiG
                                • Jan 2001
                                • 111
                                #30
                                By "cheap fan" do you mean like a desktop cooling fan?
