the upper thermal limit on an Athlon is 70c (I know, it's not a celeron)... but you're still way too high guy
CPU temperature
My Celeron Tualatin 1.2 o/c'ed to 1380 at stock 1.475v warms up to ~40c (case temp 26c) running Prime95 torture test and/or cpuburn burnp6.exe. This is with an Alpha 6035, 23.5 cfm fan, and original AS grease.
well, there is a 0.05 micron difference between the tualatin and coppermine core so a difference is to be expected, but i just found out my "arctic silver" isnt real arctic silver.Main Machine: Intel Q6600@3.33, Abit IP-35 E, 4 x Geil 2048MB PC2-6400-CL4, Asus Geforce 8800GTS 512MB@700/2100, 150GB WD Raptor, Highpoint RR2640, 3x Seagate LP 1.5TB (RAID5), NEC-3500 DVD+/-R(W), Antec SLK3700BQE case, BeQuiet! DarkPower Pro 530W
Whatever you do, change that HS setup right now. 70c is extremely high. It seems you're not so willing to go and spend some hard earned cash on a neew cooler, but you have to.
Get a decent SocketA heatsink that fits and mount it on and it should never go above 50. Do it now and don't use your computer until you get a new cooler.
That cooler suxs! Sorry m8 but thats the conclusion I came to with that cooler barley enough to cool a 400MHz celeron!Originally posted by knirfie
well i have to say it's doing a pretty good job passivlyAccording to the latest official figures, 43% of all statistics are totally worthless..
with the socket 7 cooler is doesnt go above the 55 as long as i dont start watching video's and stuff, so i guess it'll have to do till i can get a new one (i just wont do any processor intensive stuff).
so what cooler do you guys recommend?
i dont have a lot of space due to the slot 1 converterMain Machine: Intel Q6600@3.33, Abit IP-35 E, 4 x Geil 2048MB PC2-6400-CL4, Asus Geforce 8800GTS 512MB@700/2100, 150GB WD Raptor, Highpoint RR2640, 3x Seagate LP 1.5TB (RAID5), NEC-3500 DVD+/-R(W), Antec SLK3700BQE case, BeQuiet! DarkPower Pro 530W
That 55 at idle and 70 when you do anything aint going to cut it. But hey, it's not my CPU!
Get a Thermaltake Volcano (whatever), it's cheap and sufficient for your CPU.
Edit: Oops, missed the Slot 1 converter. disregard what I proposed. Although a Taisol CGK760092 should fit, but be shure to check it though as it may not be compatible.Last edited by Novdid; 17 December 2002, 15:06.
Actually no, get a copper 1u socA/370 hsf.
Alternatively, use it to cook some eggs and perhaps beacons and put them in a roll with ketchup.P4 Northwood 1.8GHz@2.7GHz 1.65V Albatron PX845PEV Pro
Seems that is an alarmingly popular trend. If you contact Arctic Silver with the purchase information for the fake stuff, they'll send you some real AS for free.Originally posted by knirfie
why don't you just get some new fans for the old cooler, what temps did it get when the fans were working?.
Umm, hate to break the party,
But 80C is probably fine.
Well, it will probably be fine for as long as knirfie wants to keep his current CPU
I still recommend something better, but if its not crashing/locking, then I don't see how it is damaging things the way it is.80% of people think I should be in a Mental Institute
81 C
I'm doing ~45 in the hottest of summer days and right now 34. Over 50 you should really worry, overclocked or not.
Find yourself a new cooler
something with a large enough heatsink and a slim fan or a slim copper heatsink and a high rpm fan.
@Admiral: total agree. my thunderbird 1.4 (HOTHOTHOT) only goes up to 47 max on the hottest summer days. 81 C... ehh...
problem goes into the records for "hottest running CPU without freezen"
... but.. 81... i dun even know how to describe that.
