Weird Problem
  • ALBPM
    • 3868
    • ALBPM
      • 3868
      LOL..... I think I need a bigger case for all those suggestions
      • KvHagedorn
        • 10725
        Or you could just get yourself one of those giant floor fans from wal-mart for about $29.00, pull the side off the case, and get a serious breeze blowing directly on the motherboard. It would supercool the whole thing, and there's nothing simpler than air movement to discourage condensation, unless your humidity is so high that the air is supersaturated.. in that case, I like Rag's solution best.. those little silicate pouches should work well.. another simpler solution might be dry white rice. That keeps salt from clumping in damp climates, and might be easier to put your hands on than silicate.
        This might be an unintentional side effect of using one of those "bong coolers" too, or any other evaporative type cooler.. high humidity right next to your case..
